Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Node properties question
iaminit
when you create maps to monitor your nodes, is there a way to customize what gets displayed when you hover over a monitored device through the web interface? For instance, when you put your mouse over a monitored server, it tells you the name, ip address, status, and vendor.
Is it possible to customize what gets displayed with this mouse over function?
Find more posts tagged with
Accepted answers
All comments
larry.rice
Thats a great question. I know you can use labels to get more information using macros...
see:
www2.solarwinds.net/.../topic.asp
Displaying more information on maps
by: ianp
trm33
Try looking here
trm
iaminit
thanks. I hadn't noticed that my original post had gotten a reply. I went to the MapToolTipTemplates.asp for the admin page and I see where it lets you modify, but I don't see where the original settings are. I'm a little hesitant to mess with it if I can't undo it. Maybe if I just make a backup of that file I will be alright. Has anyone played with this with any success?
trm33
yes we have these set up
Ckt: ${Circuit_Id}${CR}MAC: ${PhysicalAddress}${CR}IP: ${IPAddress}${CR}Port: ${SwitchPort}${CR}In: ${Inbps}${CR}Out: ${Outbps}${CR}Max In: ${MaxInBpsToday}${CR}Max Out: ${MaxOutBpsToday}
Network_Guru
Also see this topic:
You can add this feature (among a few others) to the menu on the left side of the admin page.
-=Cheers=-
NG
iaminit
ok, I got it working so it displays what I want when I put my mouse over the node. This is a really nice feature. However, is there a way to tell the code not to display that particular variable if there is no value for it?
for example, if I have a custom property for circuit id's for nodes, every node I have on the map will display that when I do a mouse-over, but obviously only the nodes with an actual value will have any info. I have a lot of servers being monitored and it just comes up with an empty value for circuit id's. I'd like to be able to turn it off. Is this possible? I didn't know if maybe there was some special syntax to the code that is put in?
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
