Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Support of VPN
rmnp0829
Does anyone know if there are plans to monitor IPsec and/or GRE throughput for VPN-based networks? This would be a tremendous value.
Find more posts tagged with
Accepted answers
All comments
Wilton
Yes it does as the GRE tunnel is seen as just another interface on the router... However, you may not be able to get accurate status information on the interface provided u run GRE keepalive...
BakerD
We have a VPN tunnel from a PIX to a Concentrator and I have looked at both using the list resources and do not see any vpn tunnel interfaces.
How does one go about getting this setup to monitor the traffic on a VPN tunnel?
iunderwo
In order for SW to actually watch a tunnel, it needs to be a GRE tunnel.
If you're using an IPsec transform-set and a crypto-map, it doesn't create an interface since its magic is performed on the transit interface on traffic going out or coming in.
It's seems rare for any VPN servers to create tunnels for their ipsec traffic.
// Ian Underwood - Service Management
// Level 3 Communications
gneltnor
Add the following to your PIX config from global config mode:
snmp-server host inside x.x.x.x poll <----add IP of SNMP/ORION Server
snmp-server community ?????? <----whatever community string you use
snmp-server enable traps
management-access inside
Then add a new node in orion to track the e1 interface (internal network) of pix. This will let you track pix ezvpn to concentrator connections.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
