Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Using Multiple NICs with NPM
dcollard
Does SolarWinds support using multiple NICs, connected to separate networks, on a single laptop?
The Checkpoint firewall blocks SNMP traffic between 3 DMZs and I need to monitor network performance on switches in all 3 DMZs with only 1 laptop. The workaround idea is to add 2 more NICs to the laptop and connect each NIC to a different DMZ. Should this work?
Find more posts tagged with
Accepted answers
All comments
Bryan
I am running something similar with a workstation. It works fine, you may need to tweak your computers routing table by adding some presistant routes. But it works!
Lockheed Martin
Atlas V Launch Operations
Network Engineer
Network_Guru
That is not following best security practices to bypass your FW with the laptop.
You are better off to add a FW rule to allow SNMP 'gets' only from your Internal trusted network to your DMZ switches.
-=Cheers=-
NG
mjhamilton
I totally agree with Ng.. using multiple nics over dmz is a bad idea..... if this laptop is hacked the whole firewall will be breached and bypassed..
use the rules for the device ip address and snmp
Martin J. Hamilton... lost in a sea of snmp...
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
