Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Use a Visio diagram with linked, dynamic shapes.
dustin.loftis
I would like to use Solarwinds to update a highly intricate, dynamic Visio diagram, displaying not only text outputs, but converting percentages of dropped packets and interface utilization into color/size graphs for each of the external routers we are monitoring.
Since we already own Solarwinds, I would like to see if anyone has any input into this question.
I would like users at our NOSC to be able to open this file up locally, as it auto-updates from a database, and monitor their particular portion of the country, or the entire map, as they prefer, without further intervention on their part.
Dustin Loftis
Find more posts tagged with
Accepted answers
All comments
Network_Guru
I'm not sure I understand the question, but if you using Orion, it includes a MapMaker application that does this for you.
-=Cheers=-
NG
dustin.loftis
Compared to Visio, Mapmaker is maddening to use, without basic layering controls, transparency adjustments, etc...
Is there a simpler way to make Solarwinds utilize a visio-created map?
Network_Guru
OK, If you don't mind a bit of pain once in a while, here's a solution:
- Take your Viso diagram and save it as a JPG(remember the exact size you saved it as).
- Save this JPG on the Orion server
- Create a new map, with the saved JPG as the background.
- Now drag all the Network components onto the background diagram.
When you make changes to your Viso digram, try not to move anything around.
Then save it as a JPG with the exact same dimensions as the previous JPG.
When you replave the JPG on the Orion server, everything should still line up.
Just delete/drag any removed/new nodes/interface as appropriate onto the new background.
Also it is possible to copy objects from Visio into Mapmaker.
Do a search in the Orion forum (where this post should be) for Visio & Mapmaker
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
