Hi:
Is a good idea issue a shutdown on Orion pollers on Sundays?
( to free up Windows memory, resources, etc...)
why?
Do you have problems with it's resources?
if you are experiencing memory leaks, make sure to update to NPM 9.5.1 and APM 3.1.
With previous versions I have had memory leaks which lead to Orion utilizing all available RAM until the services were restarted...
with the current versions I let them run until they lose connection to the database once, if that happens I need to restart the services again as well.
