Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
How can a switchport peak at over 300%?
jlapham
While running Network Performance Monitor I have a 3Com 3300 switch with a maximum percent utilization graph hitting 200% to 300% frequently.
How can this happen? and Why?
John
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Check the bandwidth setting of the interface.
If it is not set correctly on the interface, then NPM will use this figure for calculating the percent utilization.
You can adjust either the monitored device, or manually in the interface properties in NPM.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
