I have a couple services that will not start on my fresh Patch management install.
The collector service and JobEngineSVC2. I have tried a repair of the services and a complete un-install and re-install to no avail. Any ideas?
Application: SWJobEngineSvc2.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: SolarWinds.JobEngine.JobEngineException
Stack:
at SolarWinds.JobEngine.ServiceProcess.SolarWindsService.ServiceStart()
at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
Application: SolarWinds.Collector.Service.exe
Exception Info: System.Reflection.TargetInvocationException
Stack:
Server stack trace:
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.Activator.CreateInstance(Type type)
at SolarWinds.Collector.OrionCommon.OrionConfiguration.get_ConnectionString()
at SolarWinds.Collector.OrionCommon.DatabaseFunctions.OpenNewDatabaseConnection()
at SolarWinds.Collector.OrionCommon.SqlHelper.ExecuteNonQuery(SqlCommand command, SqlConnection connection, SqlTransaction transaction)
at SolarWinds.Collector.CollectorServiceApp.WaitForDatabaseConnection(IDBWatcher dbWatcher)
at SolarWinds.Collector.CollectorServiceApp.Start()
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
at SolarWinds.Collector.CollectorService.InternalStart()
