Good afternoon team,
Open Discussion/Question.
I would like to get sources of Alerts the folks have built out in SaaS. I've reviewed the documentation for common Alerts " SolarWinds Observability | Examples of common alert definitions" but would like to see what type of cool alerts the community has built out.
I have the same question - I can see the lastboot time stated on the entity health age but cannot seem to use that value anywhere within an alert. I noticed you can do it when using the SWO agent but not agentless.
Here is an alert I would like to build eventually in Saas. I had this alert in Orion previously but can't seem to replicate it in SaaS
an alert that logs was rebooted - and sends a monthly or daily report of those devices that were rebooted
