Hi - need some swql for a KPI Widget for the number of component being seen in a warning or critical state and including "CustomProperties.CoreProductionSystem = YES" - thanks
Any help on this would be very much appreciated - thanks
Hi JasonFord1971,
Here's 2 SWQL commands that'll work for you.
(Option 1) Combined count with the status of 'warning (3)', 'critical (14') and 'down (2)'. If you don't want to add down simply remove it from the query.
SELECT DISTINCT count (a.componentname) as [Puppy]FROM Orion.APM.Component aWHERE 1=1 and a.application.node.CustomProperties.CoreProductionSystem = 'yes' and a.status in ('3','14','2')with nolock
(Option 2) Separate KPI's for warning, critical and/or down
SELECT DISTINCT count (a.componentname) as [Puppy]FROM Orion.APM.Component aWHERE 1=1 and a.application.node.CustomProperties.CoreProductionSystem = 'yes' and a.status = '3'with nolock
SELECT DISTINCT count (a.componentname) as [Puppy]FROM Orion.APM.Component aWHERE 1=1 and a.application.node.CustomProperties.CoreProductionSystem = 'yes' and a.status = '14'with nolock
SELECT DISTINCT count (a.componentname) as [Puppy]FROM Orion.APM.Component aWHERE 1=1 and a.application.node.CustomProperties.CoreProductionSystem = 'yes' and a.status = '2'with nolock
Thank you - just what i needed
Could you confirm what the SWQL would look like without CustomProperties.CoreProductionSystem = YES" - thanks - thanks
Sure
SELECT DISTINCT count (a.componentname) as [Puppy]FROM Orion.APM.Component aWHERE 1=1 and a.status = '3'with nolock
thank you
