Wouldn’t it be better if we had two options for exam registration? Currently, PSI often causes issues (check marks failing, mic or webcam not working). Having Pearson as an alternative could give more flexibility. Do you agree?
@thwackahsanpk Thanks for sharing, we understand how frustrating those technical issues with PSI can be. Your suggestion to offer Pearson as an alternative is appreciated and could definitely improve flexibility. We're actively exploring better exam delivery options and will share updates soon.
- Judessa Quiod, SCP Program Manager
Thank you for considering this suggestion. I’ll look forward to the updates...
