Is it possible to point switches and firewalls SNMP settings to the NPM server's IP address using the community string, etc?
the module is LogViewer / LogAnalyzer. The first is included with the core platform and is able to receive Syslog/Traps.
Could you elaborate what you are trying to achieve?
I would like to setup an SNMP server that my switches and firewalls can point to. Thank you.
What do you mean „can point to“? Is it that your devices will be sending SNMP Traps to the Solarwinds Server? If so, there’s no need to set anything up on the Solarwinds side, it is a base functionality. Solarwinds is „listening“ on Port 162 for Traps already
Sorry I should have been more clear. Our switches point to a SNMP collector device with a config such as: snmp-server host 192.168.2.7 version 2c snmp-community-string
I was wondering can I point our devices to the SolarWinds NPM server's IP address like in the example.
OK, this is the SNMP Trap config. Yes Solarwinds is by default configured to receive Traps. You will find the Traps by opening „Alerts & Activiity“ menu -> Traps.
the prerequisites are that the device sending the traps is configured as a monitored Node.
