After upgrade to 2025.2 the wireless summary view doesnt load. Anyone else with similar issue? Support case opened.
Case # - 01967740 Wireless Summary View is not loading (blank)
thank you,
Hello, do you have any update from Orion support? Looks like we hit the same issue... thank you
much appreciated, I will keep you posted.
Thanks I am still awaiting updates linked them to your case
HI Steve, I'm afraid the issue came back after a few days, reverting back to support.
But during that time i assume you would not be monitoring?
We managed to resolve this by unmanaging all the WLCs, clearing the wireless access point DB table, and -remanaging the WLCs, after a few hours the wireless summary view started working again.
I am in the early phases of support only uploaded diagnostic yesterday will keep you posted
Hey Steve, yes that is correct searching for AP by name is working. the most recent response from support, is to rebuild the website.I',m using an AWS.
If you search for an AP by name it still works
Yes I have the same issue 01971355
