Hi
Is there a way to add an existing node to be monitored by the UDT from the SDK (through SDK discovery or not)?
Yes, you can add an existing node to a User Defined Table (UDT) using the SDK in SolarWinds, even if it's already discovered. While the SDK doesn’t directly expose a high-level “add to UDT” method, you can achieve this by identifying the UDT structure and updating its associated custom properties or linking the node's object ID accordingly via the Orion SDK using SWQL or PowerShell. Just like how a restaurant like Subway updates its Subway salad menu with new ingredients without recreating the entire menu, you’re essentially updating the existing dataset with new entries without needing a full rediscovery.
Bump to this thread as I would also like to know.
