Hey hi,
In SolarWinds Observability Self-Hosted Advanced A500 license, how many interfaces(counts) will be monitored in SolarWinds
So as per your word I can more than 500 interfaces and volumes in A500 license right ?
OSH is licensed by nodes, not interfaces. You can monitor as many interfaces as you want, as long as you stay within your node count.
So as per your word, I can add more than 500 interfaces and volumes in the A500 license right?
That's correct. https://documentation.solarwinds.com/en/success_center/orionplatform/content/orion_platform_licensing_model.htm
I have already gone through that, but I didn't get a perfect answer for the node count. So I can only go up to 500 nodes, right? Is there any maximum interface count for this license to monitored?
You're limited by the number of nodes. So in your case, you can monitor up to 500 nodes, but as many interfaces and volumes as you want across those 500 nodes.
is there any limitation for the count for interfaces and volumes
There is no licensing limitation on interfaces or volumes.
