Hi - need some SWQL for
1 - disk volume usage for modern dashboard
2 - Which widget would be the best to use
thanks
Sorry that's my bad!!!! I forgot to add the "where" statement.
This should do the trick.
FROM Orion.Volumes AS vwhere v.Node.CustomProperties.CoreProductionSystem LIKE '%YES%'with nolock
Hi @jasonford1971 it all depends on what you want it to display you can do a straight forward table or you can build a Perfstack and put it in the Modern Dashboard.
Hi Jasonford1971, while I agree with LebeauUK I would be very careful with the PerStack option. Personally, I would only suggest that if you want to show of 4-5 drives, any more than that then you could potentially see a web performance degradation at least on that page/tab.
Here's my 3 standard modern drive performance widgets that I build for all of my customers. Side note, there are a few variances like disposition & system drive versus non-system drives. But all-in-all my customers love these.
Here's my standard production/system drive query:
SELECTv.Node.Caption AS [System Name]--**remove the below line if you don't care about system/non-system drives.**,CONCAT(v.DeviceId,'/') AS [Drive], round(v.DiskQueueLength * 1.0 ,3) as [Disk Queue Length], round(v.DiskTransfer * 1.0 ,3) as [Disk Transfer], round(v.DiskReads * 1.0 ,3) as [Disk Reads], round(v.DiskWrites * 1.0 ,3) as [Disk Writes], v.Node.DetailsUrl AS LinkForNode, v.DetailsUrl, v.Icon, v.StatusIconFROM Orion.Volumes AS vWHERE 1=1 and (v.DeviceId = 'C:') --**If you use custom properties for you teams replace lines below with your own custom property. --**the script below covers systems with or without a responsible team custom property. and (v.Node.CustomProperties.Responsible_Team = 'Server_OPS' or v.Node.CustomProperties.Responsible_Team is NULL) --**The lines below cover disposition based off of our custom properties. and (v.Node.CustomProperties._Disposition = 'PROD' or v.Node.CustomProperties._Disposition is NULL)with nolock
Here's what this widget looks like:
Here's my widget for drive space, again I'm focused on the system drive, production systems and systems supported by a certain team.
SELECTv.Node.Caption AS [System Name],CONCAT(v.DeviceId,'/') AS [Drive],CASE WHEN V.size >= 1099511627776 THEN CONCAT(ROUND(V.size/1099511627776,2), ' TB') WHEN V.size >= 1073741824 THEN CONCAT(ROUND(V.size/1073741824,2), ' GB') WHEN V.size >= 1048576 THEN CONCAT(ROUND(V.size/1048576,2),' MB') WHEN V.size >= 1024 THEN CONCAT(ROUND(V.size/1024,2),' KB') Else '0' END as [VolumeSize],CASE WHEN v.VolumeSpaceUsed >= 1099511627776 THEN CONCAT(ROUND(v.VolumeSpaceUsed/1099511627776,2), ' TB') WHEN v.VolumeSpaceUsed >= 1073741824 THEN CONCAT(ROUND(v.VolumeSpaceUsed/1073741824,2), ' GB') WHEN v.VolumeSpaceUsed >= 1048576 THEN CONCAT(ROUND(v.VolumeSpaceUsed/1048576,2),' MB') WHEN v.VolumeSpaceUsed >= 1024 THEN CONCAT(ROUND(v.VolumeSpaceUsed/1024,2),' KB') Else '0' END as [Space Used],CASE WHEN v.VolumeSpaceAvailable >= 1099511627776 THEN CONCAT(ROUND(v.VolumeSpaceAvailable/1099511627776,2), ' TB') WHEN v.VolumeSpaceAvailable >= 1073741824 THEN CONCAT(ROUND(v.VolumeSpaceAvailable/1073741824,2), ' GB') WHEN v.VolumeSpaceAvailable >= 1048576 THEN CONCAT(ROUND(v.VolumeSpaceAvailable/1048576,2),' MB') WHEN v.VolumeSpaceAvailable >= 1024 THEN CONCAT(ROUND(v.VolumeSpaceAvailable/1024,2),' KB') Else '0' END as [Space Available],CONCAT(round(V.VolumePercentAvailable,1),'%') AS [Percent Available],ROUND(VolumePercentUsed, 2) AS [Percent Used], CONCAT (v.PercentDiskUsedThreshold.Level1Value,' %') as [Warning % Threshold], CONCAT (v.PercentDiskUsedThreshold.Level2Value,' %') as [Critical % Threshold], '/Orion/images/ForecastingIcons/volumeutilization.png' AS [_IconFor_Volume], '/NetPerfMon/images/Volumes/' + v.icon AS [_IconFor_VolumeSize], '/Orion/images/StatusIcons/Small-' + v.StatusLED AS [_IconFor_Percent Used], v.Node.DetailsUrl AS LinkForNode, v.DetailsUrl AS LinkForVolumeFROM Orion.Volumes AS vWHERE 1=1 and (v.DeviceId = 'C:') and (v.Node.CustomProperties.Responsible_Team = 'Server_OPS' or v.Node.CustomProperties.Responsible_Team is NULL) and (v.Node.CustomProperties._Disposition = 'PROD' or v.Node.CustomProperties._Disposition is NULL)with nolock
and here's what this widget looks like:
Lastly, for the hat-trick I supply this forecast widget
SELECTN.Caption as [System Name],N.DetailsUrl as [Node Link],N.Volumes.DetailsUrl as [Drive Link],CONCAT(n.Volumes.DeviceId,'/') AS [Drive],CASE WHEN F.DaysToWarningAvg is NULL THEN tostring('Not Calculated') WHEN F.DaysToWarningAvg <= 0 then tostring('Now') WHEN F.DaysToWarningAvg >= 1825 THEN tostring('> 5 Years') WHEN F.DaysToWarningAvg >= 365 THEN tostring('> 1 Year') WHEN F.DaysToWarningAvg >= 90 THEN tostring('> 90 Days') WHEN F.DaysToWarningAvg >= 60 THEN tostring('> 60 Days') WHEN F.DaysToWarningAvg >= 30 THEN tostring('> 30 Days') ELSE tostring(tostring(F.DaysToWarningAvg) + ' Days') END AS [Warning], CASE WHEN F.DaysToCriticalAvg is NULL THEN tostring('Not Calculated') WHEN F.DaysToCriticalAvg <= 0 then tostring('Now') WHEN F.DaysToCriticalAvg >= 1825 THEN tostring('> 5 Years') WHEN F.DaysToCriticalAvg >= 365 THEN tostring('> 1 Year') WHEN F.DaysToCriticalAvg >= 90 THEN tostring('> 90 Days') WHEN F.DaysToCriticalAvg >= 60 THEN tostring('> 60 Days') WHEN F.DaysToCriticalAvg >= 30 THEN tostring('> 30 Days') ELSE tostring(tostring(F.DaysToCriticalAvg) + ' Days') END AS [CRITICAL], CASE WHEN F.DaysToCapacityAvg is NULL THEN tostring('Not Calculated') WHEN F.DaysToCapacityAvg <= 0 then tostring('Now') WHEN F.DaysToCapacityAvg >= 1825 THEN tostring('> 5 Years') WHEN F.DaysToCapacityAvg >= 365 THEN tostring('> 1 Year') WHEN F.DaysToCapacityAvg >= 90 THEN tostring('> 90 Days') WHEN F.DaysToCapacityAvg >= 60 THEN tostring('> 60 Days') WHEN F.DaysToCapacityAvg >= 30 THEN tostring('> 30 Days') ELSE tostring(tostring(f.DaysToCapacityAvg) + ' Days') END as [AT CAPACITY]FROM orion.forecastcapacity Fleft join Orion.Nodes N on f.NodeID = n.NodeIDWHERE 1=1 and ((N.CustomProperties.ITD_Responsible_Team = 'Server_Ops' or N.CustomProperties.ITD_Responsible_Team is NULL) and (N.CustomProperties._Disposition = 'PROD') or N.CustomProperties._Disposition is NULL) and ((N.Volumes.DeviceId BETWEEN 'C' and 'Z') and (F.DaysToCapacityAvg is NOT NULL))order by F.DaysToCapacityAvg ASCwith nolock
which looks like this:
I hope these help. If you want I can this view and post it on resource share.
thanks for replies - very much appreciated, are the above table widgets ?
Yes, widgets for a modern dashboard. This is what it looks like when put all together.
Have tried the above and the SWQL is not working - Provided SWQL query is not valid is the error being displayed
Hi Jason,
I just uploaded the dashboard to the Content Exchange Dashboard area.
Modern Dashboards - The SolarWinds Platform - THWACK
In case you need information on how to import a modern dashboard, here's the link. Just beware that you'll need SWQL Studio.
Import and export modern dashboards
OK - Thanks, but i dont have SWQL studio access
