How do you become a Beta tester?
AFAIK there is no public beta programme. The code is all closed source too, so all testing done in house. The nearest the public get to do any testing is by installing/using the RC versions of the software which normally come out a month or so before GA. This is for SolarWinds Platform and Observability Self-Hosted.
