ASA imported chassis for 4215 and 4150 FPR, we see blank data in solarwinds.
Can someone help ?
The device shows as off line.
Are you facing issue for all ASA. Kindly try to add them CLI.
Kindly follow the below link
documentation.solarwinds.com/.../npm-set-up-firewalls.htm
Hi Naveen, we have alot of ASA's. i am facing the issue with blank data for alot of firewalls. i tried the CLI poller and still no luck
Are you able to reach ASA's from polling engin. As it showing down in screenshot.
if they are reachable from poller try snmp walk and see the response.
open support case with Solarwinds.
Hi The poller works, have not tried the SNMP walk
do you have the link to log a support case with Solarwinds
Log in to the Customer PortalGo to the SolarWinds Customer Portal
Navigate to SupportOnce logged in, click on "Support" and then select "Submit a Ticket" or "Technical Support".
