Hi
Some one know how can i know from device to which group is belong to ?
Yes, as I said above there are LOTS of options, you just have to decide how you want to approach this.We have 10,000 devices and about half as many groups, so we have to created a widget that allows us to see at a glance what "groups" and what "maps" they appear on.
The way we have done this is:
The widget when editing looks like this:
The SWQL code you need is:
SELECT CASE WHEN m.Container.Owner = 'Core' THEN 'Group' WHEN m.Container.Owner = 'Maps' THEN 'Map' ELSE 'Other' END AS [Type], CASE WHEN m.Container.Owner = 'Core' THEN m.Container.Name WHEN m.Container.Owner = 'Maps' THEN p.DisplayName ELSE 'Other' END AS [Name], m.Container.DetailsURL AS [_linkfor_Name], s.StatusName AS [Status], '/Orion/images/StatusIcons/Small-' + s.StatusName + '.gif' AS [_iconfor_Status]FROM Orion.ContainerMembers mJOIN Orion.StatusInfo s ON m.Container.Status = s.StatusIDLEFT JOIN Orion.Maps.Projects p ON m.Container.Name = p.ProjectIDWHERE m.MemberEntityType = 'Orion.Nodes' AND m.MemberPrimaryID = ${NodeID}
The result looks like this:
Can you provide more information on what you are looking to achieve?Do you mean map group, vendor group, custom property group, etc, etc?But as an example, if I have a custom property called 'Responsible Team' I can do a number of things, including but not limited to:
So, if you can provide more info that would be great.
Unless you have something (custom additions to the view) to suggest in the node page view you cant. You will need to start looking at your groups (Manage Groups) to understand how have you built the groups (based on what logic). Sometimes it could just be the view as well based on custom properties.
But my problem is that i have 1000 devices within 10 group , each group contain dynamic query , my question is if there is option to get into device and to see from the device prespective to which group is belong to ?
Hi [@avivi],
If you're using a device management system like Microsoft Intune, Jamf, or Active Directory, you can check the group membership of a device by doing the following:
For Microsoft Intune / Endpoint Manager:
Go to Devices > All Devices
Click on the device name
Under the device's overview, scroll to see “Groups” to find which Azure AD groups it's a part of
For Active Directory (on-prem):
Open Active Directory Users and Computers
Find the computer under Computers or relevant OU
Right-click the device > Properties > Member Of tab
For Jamf (Macs):
Go to the device's details
Check the Smart Groups or Static Groups section
Let me know what system you're using — I can give a more specific answer
What is ${NodeID} mean ?
For group i mean
A group is a collection of monitored objects, such as a group of nodes from the same location, or group of all nodes owned by a department.
It refers to the NodeID of the specific node page you are on. When you navigate to another node, it uses that device's ID and so on.
Odd as it may seem, given that this is primarily a Solarwinds forum, he's trying to do this using Solarwinds.
Odd as it may seem, given that this is primarily a Solarwinds form, he's trying to do this using Solarwinds.you can see more infomation on bowmastermodapk.com
