Anyone has done any SolarWinds/ConnectWise integration?
What can be integrated?
We use connectWise for ticketing
Then the alert action can call a get/post action to create the ticket, or you can script it
yes, Connectwise has an API. We use it to integrate with our time collection system. Just be warned, the frequently make changes without announcement and break things.
you can do it using API, does connectwise has an API? you can configure in action to send a post
