I have added three custom dashboards to the Default menu in the Orion console. Two work fine, but the other one always opens in Edit mode. I have to click 'done editing' each time. Can someone tell me what's causing this?
Thanks,Joe
Can you post the three URL's you used for the menu items? Does the one opening in edit more have 'edit' in the URL?
Chad, it did indeed have 'edit' in the URL. Great catch! I've edited the link and now things are good. Thanks!!
Check Dashboard Permissions – Ensure that you have the correct permissions to modify and save dashboards. If your user role lacks sufficient permissions, the dashboard might revert to edit mode every time.
Dashboard Save State – Try making a small edit to the dashboard, then click 'Done Editing', and manually save the dashboard again. Some dashboards require an explicit save action.
Configuration File or Database Issue – If the dashboard settings are stored in a configuration file or database, there may be an issue with how it's being read. Check for any inconsistencies or errors.
Browser Cache & Cookies – Clear your browser cache and cookies, or try opening the Orion console in a different browser to see if the issue persists.
I've done all this. I've created other dashboards and have not had this problem. That's what is curious.
