I need to create an alert for SDWAN Tunnel Bouncing. Anyone has done this before?
I don't have the answer, but what model of SDWAN are you using? Cisco Viptella? Sdwan has BFD sessions. It also depends on how to setup your connectivity. Do you have every site connecting to every site, or a hub and spoke type scenario. Depending on how many peers, you could have a lot of alerts because of the internet itself.
