Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Missing Custom MIB Poller option
FormerMember
New user to Orion (7.8.5); In the demo, I was able to add custom mibs, but now with the real deal loaded, the option for Custom MIB Poller does not exist in system manager... Is this a separate add-on? Nothing I've found shows that it is.
Brian
Find more posts tagged with
Accepted answers
All comments
Network_Guru
The custom MIB poller was a beta in 7.8.5
You need to download & install the latest 8.0 version to get this working again.
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
FormerMember
Ahh,
My thanks.
Brian
bashley
NOTE: the Custom MIB Poller does not support MIB importing! This is something I have discussed with SW support at length. Although the MIB databse provided by Orion provides several periodic updates, their importer tool does not work. This is supposed to be addresed in the upcoming revision.
FormerMember
<<NOTE: the Custom MIB Poller does not support MIB importing! This is something I have discussed with SW support at length. Although the MIB databse provided by Orion provides several periodic updates, their importer tool does not work. This is supposed to be addresed in the upcoming revision.>>
Yeah, I've noticed that now.... I hope that is rectified in the next release; although for now it looks like am able to make do with existing MIBS.
Brian.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
