Hi
Trying to create a Dashboard for whole infrastructure certificate expiry check.
But stuck somewhere and we need to create an alert if expiry is near.
Like Cisco, WIndows Server, IIS, Palo Alto, SD-WAN and etc.
By Following this, we can only found IIS and VPN certificates expiry but did not get the list of device's certificates expiry
SAM can do SSL cerificate monitoring https://www.solarwinds.com/server-application-monitor/use-cases/ssl-certificate-monitor for which you can them add to dashboards
