I am new to We need to check suceesful login and failed login from the https://abc.com/login.jsp has anyone tried it
In addition to what jklundy says maldonado real estate, you can also have a powershell etc script which can perform a bit more browser interaction, or you can also use SWO/Pingdom etc
Come to think of it, in additon to what I said, if you've got a api call which logs in, then that as a component works well. The browser may use that stuff to login behind the UI anyway
In addition to what jklundy says, you can also have a powershell etc script which can perform a bit more browser interaction, or you can also use SWO/Pingdom etc
If you want to just check that the page is served properly, you can use the HTTPS component monitor and add a keyword check.If you want to actually complete a login process, you will need to use Web Performance Monitor (WPM) and not SAM.
