I’m planning to take the SolarWinds Hybrid Cloud Observability (HCO) Network Monitoring exam. If anyone has already taken it, please share your experience, preparation tips, and any helpful resources. Your guidance will be greatly appreciated!
The best approach I found was to walk through the admin guide for the topics: UnDP Pollers & Device Studio, NPM, NTA, LA.
There is also an exam prep video in available in the customer portal that walks you through some exam prep questions.
thank you for your guidelines
You cleared it?
