Would it be too much to ask to reissue a 12.3 release with the hotfix compiled to the installer? it's been over a year now and one would think this would be a no brainer.
Hi holbms, What do u mean by 12.3 release ?
The latest release of Dameware 12.3 on your webpage that requires a hotfix after install... The Hotfix should be incorporated into the install to make the installations cleaner.
The 12.3.1 installer is nice once again..
