Is there a script (SWQL) that can generate the WAP devices serial and model number?
Honestly I don't know. Somebody better versed in UnDPs may know but I don't.
Hi Stuartd,
Good day to you!
I have one question our leadership wants to include the WAP Status and able to setup the MIB on the UDP using bsnAPOperationStatus' => '1.3.6.1.4.1.14179.2.2.1.1.6' and added to the report. Is there way to show the Status definition such as associated instead of number only? Thank you
bsnAPOperationStatus Definition'1' => 'associated''2' => 'disassociating''3' => 'downloading'
Ahh yes - apologies. That one was written in SQL but glad you got it working.
It's working now using SQL good thing I was able to read some of your old post. Thank you very much
The OIDS or UDP are already set it's just the report that I can't make it work, tried the script but getting Query is not Valid. Thanks
So, you can do this but it is a two step process.
You need to create a UnDP (and assign it) to extract the serial numbers from the WLC. The second step is you need to then create a custom SWQL report to list the details out.For Cisco WLC's the OID we've been using is: 1.3.6.1.4.1.14179.2.2.1.1.17 - so go and create your UnDP (https://solarwindscore.my.site.com/SuccessCenter/s/article/Create-a-Universal-Device-Poller-UnDP?language=en_US) and these are the options we've used:
Then you need to create your repot.
The code we used is:
/* Query to get AP Information from the Controllers through the use of UnDPs, because APs are not nodes in Solarwinds but an extra to the Controllers*/SELECT DISTINCT (n.caption) AS 'Controller' ,t1.STATUS AS 'AP Name' ,t2.STATUS AS 'Serial number' ,t3.STATUS AS 'Model number' ,t4.STATUS AS 'Software' ,t5.STATUS AS 'IP Address' ,npm.ClientFROM CustomPollerStatus AS cpsJOIN CustomPollerASsignment AS cpa ON cps.CustomPollerASsignmentID = cpa.CustomPollerASsignmentIDJOIN Nodes AS n ON n.NodeID = cpa.NodeIDJOIN NodesCustomProperties AS npm ON npm.NodeID = n.NodeIDJOIN ( SELECT cps.STATUS ,cps.CustomPollerASsignmentID ,cps.RowID FROM CustomPollerStatus AS cps JOIN CustomPollerASsignment AS cpa ON cps.CustomPollerASsignmentID = cpa.CustomPollerASsignmentID JOIN Nodes AS n ON n.NodeID = cpa.NodeID WHERE cpa.ASsignmentName LIKE 'bsnAPName%' ) AS t1 ON cps.RowID = t1.RowIDJOIN ( SELECT cps.STATUS ,cps.CustomPollerASsignmentID ,cps.RowID FROM CustomPollerStatus AS cps JOIN CustomPollerASsignment AS cpa ON cps.CustomPollerASsignmentID = cpa.CustomPollerASsignmentID JOIN Nodes AS n ON n.NodeID = cpa.NodeID WHERE cpa.ASsignmentName LIKE 'bsnAPSerialNumber%' ) AS t2 ON cps.RowID = t2.RowIDJOIN ( SELECT cps.STATUS ,cps.CustomPollerASsignmentID ,cps.RowID FROM CustomPollerStatus AS cps JOIN CustomPollerASsignment AS cpa ON cps.CustomPollerASsignmentID = cpa.CustomPollerASsignmentID JOIN Nodes AS n ON n.NodeID = cpa.NodeID WHERE cpa.ASsignmentName LIKE 'bsnAPModel%' ) AS t3 ON cps.RowID = t3.RowIDJOIN ( SELECT cps.STATUS ,cps.CustomPollerASsignmentID ,cps.RowID FROM CustomPollerStatus AS cps JOIN CustomPollerASsignment AS cpa ON cps.CustomPollerASsignmentID = cpa.CustomPollerASsignmentID JOIN Nodes AS n ON n.NodeID = cpa.NodeID WHERE cpa.ASsignmentName LIKE 'bsnAPSoftwareVersion%' ) AS t4 ON cps.RowID = t4.RowIDJOIN ( SELECT cps.STATUS ,cps.CustomPollerASsignmentID ,cps.RowID FROM CustomPollerStatus AS cps JOIN CustomPollerASsignment AS cpa ON cps.CustomPollerASsignmentID = cpa.CustomPollerASsignmentID JOIN Nodes AS n ON n.NodeID = cpa.NodeID WHERE cpa.ASsignmentName LIKE 'bsnApIpAddress%' ) AS t5 ON cps.RowID = t5.RowIDORDER BY 'AP Name' ASC
You may need to edit the report code as we used several UnDP names to get a little more info returned. If you change your UnDP names from the default, then you will need to edit them in the above code.We named ours:bsnApIpAddress - OID: 1.3.6.1.4.1.14179.2.2.1.1.19bsnAPModel - OID: 1.3.6.1.4.1.14179.2.2.1.1.16bsnAPName - OID: 1.3.6.1.4.1.14179.2.2.1.1.3bsnAPSerialNumber - OID: 1.3.6.1.4.1.14179.2.2.1.1.17bsnAPSoftwareVersion - OID: 1.3.6.1.4.1.14179.2.2.1.1.8
