How to integrate solar winds Orion ncm and npm on same server for the latest version?
Hi Karunakar,
You may have already seen this, but if not, hopefully it will answer your questions. Install SolarWinds NCM
Orion platform products: integration support
If you are integrating SolarWinds NCM with another Orion platform product, the other product must be installed first on the host. SolarWinds NCM version 7.6 integrates with the following Orion platform products and versions:
Best regards,Tyler
