There is error showing on the console mentioning RunQuery failed, check fault information. Execution TimeOut Expired. The timeout period elasped prior to completion of the operation or server is not responding. So how do i check this error?
Curious if you found a resolution to this as we are getting the same menu error. Support had us stop and start some services and run the Configuration Wizard but that didn't solve the problem.
Hi @scosta ,
When i raised a ticket to Support, its the same like yours, support didnt resolved the issue, only when we did an upgrade to Solarwinds, then the error is gone from the screen. So not sure what cause the error. I could be wrong but it maybe related to database issue
Thanks for the reply.
We just upgraded to 2024.1 and that didn't resolve the issue. They want us to delete all notifications (DELETE FROM NotificationsItems) from the database. We'll see if that helps. Thansk.
Did you manage to clear the error?
Dealing with the same issue today. Any solution yet ?
Please share a case number. RunQuery is a generic error so we likely need to review the logs to see the context around the error message
Repair in process, if it didnt work then ill create a case
Sure. Repair may fix it temporary, but the RunQuery is likely a symptom of a bigger problem. The error is usually signs that SWIS is timing out due to other conditions.
