Is is possible that I can get to the admin console via SSH? If so how to setup or disable that feature? We are running 15.4.2. I know how to do to the admin console via HTTPS, I need to use SSH.
Well it sounds like an undocumented use case, so yeah I guess you could open a ticket. I thought you were asking how to do admin tasks from SSH but it sounds like you mainly just have a security use case to cover/close.
Nobody?
Serv U was primarily designed as a GUI driven tool. Notably you can see in the docs they specify that to access the admin interface you would launch it in Gnome or KDE or access the web interface. I'm sure if someone was motivated enough you could reverse engineer the settings and admin it from SSH and a bunch of shell scripts, but unfortunately it wasn't designed around that use case and it is documented/supported.solarwindscore.my.site.com/.../Install-Serv-U-on-Linux
Thanks mesverrum, but I am on a Windows box and according to our external pen test, there was no reverse engineering and it only took seconds. We do not currently have HTTPS setup to remote admin, but it was discovered that SSH'ing into the gateway brought up the admin console.. Should I open a ticket?
Thank you, yeah I couldn't find anything that said you can get to the admin console / login from SSH. I will open a ticket.
Is there an update on this?
Well, support acted like I didn't know what I was talking about. I disabled SSH but as we have to use ftp software, the SSH was needed. So I just enabled "Anti-Hammering," also known as Anti-Brute Force protection, under domain settings. and checked the box never show server information for SSH identity
