Where are all the places to reset a service account in SAM that affects WMI monitoring?
Not sure if I understand your question because its a one liner but, you can reset the password on Active Directory and edit the credential here https://SWServer/Orion/Admin/Credentials/CredentialManager.aspx
So, We have changed the password here:
Are you inheriting credentials from the node or are you using a separate set of creds?
Now , we monitor nodes (windows workstations). There are many of them. How to change the password for the service account for these?
Yes, we are inheriting credentials from the node. The service account password is used on anything in windows WMI.
Change the password on Active Directory, then update the credential with the new password on Solarwinds.
What are all the places to update the service account?
I will provide some screen shots
Solarwnd1 - are you using an Active Directory account for WMI or are you using local windows workstations accounts?
The service account is a domin service account. Does that help?
@Solarwnd1 do you know what Active directory is and how Domain controllers work?
No exactly.
I suggest you find someone in your company that does, it will make your life so much easier. I cant fathom how you have been given this task with no one showing you how to reset the service account password in the first place. And with your lack of knowledge I highly doubt you have administrative/delegated administrative access to the domain controller.
Just to throw in a potentially useful tool in the thread, there are some widgets in my admin dashboard specifically for seeing and editing which credentials are used in npm and Sam
thwack.solarwinds.com/.../viewexporter-ps1
Go to Manage windows credentials, update the new password there. It will handle everything.
