Hello, I have a fe logs that I want to export from Orion :
But I don't see any button for doing so.
Where can I get these ?
Regards.
seems like some limitation - export button is present on my side.https://documentation.solarwinds.com/en/success_center/la/content/lm/lm-filter_and_export_search_results.htm
what can I do to have the right to do it ?
Unsure to be honest, I looked on our environment but couldn't find any account rights relating to Log Viewer and exporting logs. Which leads me to think that it might not be account related but product/licensing related.@adam.beedell @vinay.by any ideas?
Not sure, I've got the export button too, suspect the same as you, need to get a lab back up. I still had an export button with a low-rank account so it's not from Admin or anything.
I expect it comes down to if you've got the proper log product or the free one. Would confirm with support. My guess is @emalto you've got NPM, but not HCO or LA or (maybe) VMAN?
This feature is only available in Log Analyzer (paid version), not the SolarWinds Platform Log Viewer. If you have LA then you would see this.
__PRESENT
Thanks for confirming @vinay.byWe have HCO so licensing is all included.
