Greetings,
I would like to integrate site2x7 with solar winds to monitoring websites.
Your support is appreciated.
Thank you,
Do you mean to say you want to monitor websites on SolarWinds using SAM for just 2 hours in a day ?
It looks like they mean this other monitoring service - Site24x7 offers both free & paid monitoring services for your entire IT environment. Monitor the health and performance of websites, servers, networks, ...
What exactly do you mean by integrate? I use both products extensively and know of no direct integration. What are you trying to accomplish?
To echo @jklundy here: we need more info on the task. I would see that you can ingest monitoring data from Site24x7 via the API into SolarWinds, as it seems to be a saas Solution, I would see it easier to pull info from the SWI side, than to push info from 24x7. I would start creating a ICMP/Externa, Node for www.site24x7.com (or whatever TLD your instance is hosted) and the create a SAM -API Poller for it. With this you can then set your API requests. Here's the API Doc for Site24x7 | API Reference
Thank you for your reply.
Yes, I want to do fully integration between site 24 and solar winds l
I need to see all the montoring websites from site 24 to solarwinds in one centralized tool.
I need to see all the montoring websites from site 24 to solarwinds in one centralized tool by linking site 24 to solar winds.
I have site24 and solar winds product
I am wondring if I could link these solution together by any chance.
For our user Dashboard links we created a site 24x7 dashboard and added the link under My Dashboards. It is not integrated but any end user using My Dashboards will be able to bring up the site 24x7 link in Solarwinds.
I have looked to some artical on API mostely they require coding to get started.
Yes, since neither vendor has made an official integration for you then there will be some level of basic coding involved to roll your own. Or you can contract people like @HerrDoktor and others to do the coding for you, if thats not something you are equipped for.
@mesverrum if it ever comes to this, we can do a round of rock, paper, scissors who will do the coding
Thank your for your reply
How can I find your Dashboard
