Hi Queen @ChrystalT .
I think it would be nice also to have a view of the thwack point history
This way we can view where and when did we earn and use the points.
Thank you.
I agree with this so that we have a track of points that has been credited and not yet.
Go to your profile and click on the lifetime points numbers, it's a link and shows you how you earned your points.
@l.mendoza @dsimpkins is correct. This is currently the only way to track your point gain and spend. There is no way for you to track points that have not been credited yet. If you feel you're missing points that should have been credited, please reach out to @kpina
Agreed.It will be good see our 'Life Time Points' earned as our THWACK Points Displayed in the Top Right of the screen.We will be able to see how many we have available to spend when we choose to go to the THWACK Store.
