This issue is specifically for the System Information section having incorrect information populated (ss below) not the Node Details or Custom Properties settings, those sections all have correct info. Nothing will allow the field to update to the correct name. I have tried re-polling, re-discovering, switching back and forth from agent to polling. The only way to fix the incorrect name in that field is the remove and re-add the node which is time consuming as all custom property fields then need to be manually entered again. Any suggestion appreciated.
Additionally, it seems like it is a link text issue perhaps as when you select the incorrect name from this section it just scrolls up to the top of the current page, not the another node.
