Does Cirrus currently support running on a Windows 2003 x64 OS? If not will this be supported in a future release?
Cirrus v4.0.1 should run fine on 64-bit OS. We are also thoroughly testing v5 (due out soon) on 64-bit 2003.
Thanks for the reply Chris, that was the answer i was hoping for
