solarwinds diagnostics gets stuck on database detailed table schema.
I have tried running the configuration wizard as well before running the diagnostics. i am running 2023.3.1
Any idea?
I'm assuming you get the same from the UI Settings -> My Deployment -> Diagnostics tab
Probably best to log a SR with Support.
got stuck here at the same place too...i was able to fix it though. Thanks
So what did you do to fix it?
what you did to fix ?
I checked in the logs, strangely SW admin service on 2 other Additional pollers were hung , i guess, I restarted the admin service on those 2 server, then the diagnostics completed , without error
good move!
I agree. Reading through the errors and issues, you should consider contacting support. If you have a successful Diagnostics, be sure to tell them and they'll give you a secure link to upload. If not,they can assist you with that issue as well.
