With increase number of nodes it is hectic to track which nodes are muted or planned to mute.
Do we have any Report/ Dashboard that can show me which nodes are currently in maintenance mode ?
I am using version 2024.1
check out this custom report Muted Element Report
Can you share me the SQL query ?
SWQL - the only issue i have with this report which i havent had time to look into is that it shows multiple entries for servers and different users who muted it.
SELECT DISTINCT [EntityUri], [SuppressFrom] AS [UtcSuppressFrom], [SuppressUntil] AS [UtcSuppressUntil], ToLocal([SuppressFrom]) AS [LocalSuppressFrom], ToLocal([SuppressUntil]) AS [LocalSuppressUntil], CASE WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%' AND [EntityUri] NOT LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/%' THEN [N].[Caption] WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Interfaces/InterfaceID=%' THEN [I].[FullName] WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Applications/ApplicationID=%' THEN [AA].[FullyQualifiedName] ELSE 'SomethingElse' END AS [Element], CASE WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%' AND [EntityUri] NOT LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/%' THEN [N].[DetailsUrl] WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Interfaces/InterfaceID=%' THEN [I].[DetailsUrl] WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Applications/ApplicationID=%' THEN [AA].[DetailsUrl] ELSE 'SomethingElse' END AS [DetailsUrl], CASE WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%' AND [EntityUri] NOT LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/%' THEN [N].[Status] WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Interfaces/InterfaceID=%' THEN [I].[Status] WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Applications/ApplicationID=%' THEN [AA].[Status] ELSE 30 END AS [Status], [AE].AccountIDFROM Orion.AlertSuppression AS [AlertSup]LEFT OUTER JOIN Orion.Nodes AS [N] ON [AlertSup].[EntityUri] = [N].[Uri]LEFT OUTER JOIN Orion.NPM.Interfaces AS [I] ON [AlertSup].[EntityUri] = [I].[Uri]LEFT OUTER JOIN Orion.APM.Application AS [AA] ON [AlertSup].[EntityUri] = [AA].[Uri]LEFT OUTER JOIN Orion.AuditingEvents AS [AE] ON [AE].AuditEventMessage LIKE CONCAT('%', CASE WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%' AND [EntityUri] NOT LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/%' THEN [N].[NodeName] WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Interfaces/InterfaceID=%' THEN [I].[InterfaceCaption] WHEN [EntityUri] LIKE 'swis://%/Orion/Orion.Nodes/NodeID=%/Applications/ApplicationID=%' THEN [AA].[Name] ELSE 'Wrong' END, '%') AND [EntityUri] LIKE CONCAT('%=', [AE].NetObjectID)INNER JOIN Orion.AuditingActionTypes AS [AT] ON [AE].ActionTypeID = [AT].ActionTypeIDWHERE [AT].ActionTypeDisplayName LIKE '%mute%'
Thanks a lot its very helpfull for me. For all the nodes I have customer wise custom properties created like "Customer" I will appreciate if you can help me to filter that data by adding custom properties as customer through that SQL.
