We'd like to monitor expiration of Active Directory certs.
I'm wondering if there are any suggestions.
I think what you're thinking of, other people might use the phrase PKI as a convenient search term
Hard to tell though
There's a few certificate monitoring things knocking around on here. In pratice it's rarely straightforward, there's always more certificates than you think and a large percentage of them dont matter
What would you imagine it doing?
As long as it is bound to a port, it could be monitored using https://support.solarwinds.com/SuccessCenter/s/article/How-to-Monitor-an-SSL-Certificate-and-Create-an-Alert-in-SolarWinds-SAM-When-There-Are-X-Days-Before-Expiration.
Thanks for the reply. I specifically want to monitor the expiry of AD certs on DCs that they use for replication events
Thanks for the reply. We have used that SSL monitoring and alerting on trad web serers. The AD certificates aren't quite the same
this thing?learn.microsoft.com/.../0ff3a848-e0a1-43ba-905b-e1895d941191
that appears to be it, thanks
So, I wonder how I can monitor the expiration of these replication certificates....?
Feels like a SAM powershell one.
Find a query that lists this specific cert, then find the property on the result that contains the expiration.
Format a short string on the cert details you care about, that's the message
Format the days remaining as an int, that's the statistic
Output the message stastic pair in a set of write-hosts
Add an exit code
Figure out best creds and whatnot.
There's prior work you can pull on for sure
I agree. I was just testing out a PS to get the info. Thanks for the reply and suggestions
