Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SESSION TIME OUT = 0
pablost
As i read in this page, i changed the session timeout to 0. After that i couldn´t enter anymore to the website.
The error is something like: SessionID =0.......please helpme, i don´t know what to do, i tried everything, reinstall web service, delete web folder and install it, but nothing....
pd: network guru wrote:
"Check the settings page in the Web administration;
"Session Timeout xxx minutes
The number of minutes of inactivity before Network Performance Monitor will automatically logout a user. "
You could try setting this to 0 minutes, which most likely will give infinite login time."
i tell you: tried not to post thing that you don´t know....because of you post i have this big trouble.....
Find more posts tagged with
Accepted answers
All comments
Levi
You must be running an older version. In the newest build, the website will not allow you to set the timeout to 0.
To fix the website, you will need to directly edit the webengine database. With MS Access, open the file NetPerfMon.WebEngine in the WebEngine subfolder. I believe it's in the Settings table. Just change the time out, save the database and log into the website.
Network_Guru
My bad, Sorry Pablost.
As Gonzajoh said in another post, if you have paid for maintenance on your software,
then it's best to get help from Solarwinds directly on technical issues.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
