Greetings to the community
I'm having problems loading SolarWinds on Google Chrome and Edge, it only loads with Mozilla Firefox. What I get in Chrome is NET::ERR_CERT_AUTHORITY_INVALID.
Does anyone know how I could solve it? Thanks in advance
did you clear the cookies and cache?
Did you deploy with https? Is it trying to use a self-signed certificate?
