Hi thwackers,
Is there a way where we can change the component Linux CPU load average and Memory by Vinx to CPU and Memory by solarwinds for 600 devices in one go??
Please let me know .
you can use the web api, or as a simpleton like me, go to the device poller and disable them.
All Settings > Device Poller
Select the Linux CPU device poller and click Assign. From there click through all the devices you want removed and disable poller. I believe it should default back to Solarwinds..
Thank you for your response, Is there a way i can group the devices that i want then disable the poller? just to be sure i don't disable it from the other devices using vinx.
I use the search bar. Hopefully you have a good naming convention.
if I need to find UPS, I will search for %UPS% and it will find all devices with UPS in the name.
hope that helps.
every device is having a different name, cannot group it like this. slight problem with your solution.
when i disable the poller it is removing the CPU and Memory entirely, not going back to the default like you mentioned, The screenshot below is from one of the device i removed
Sorry about that.
You can do the reverse and go into the CPU & Memory by solarwinds and assign the nodes using enable poller. You may need to scan the nodes before enabling.
you can skip the step of disabling and just enable onto this poller and it should remove it from the Linux CPU poller.
will try this. Sorry to bother you , but is there a script i can run on DB to get it done?
Probably a TSQL script. Maybe the guys tomorrow can come up with it.
How are you grouping them? Machine type, custom property, etc?
i created a different CP for the device and grouped the devices under it. i did the reverse for it, it is sorted for now.
