In the Alerts section there's a button you can click to acknowledge an alert which pops up with the following which you can enter notes in, is there a way to recreate this in a custom table using a SQL query?
Great thanks, I'll give that a go.
Hi, with below query you see all unacknowledged alerts and the link to the right "ack's" the alert. But you don't get any popup....
SELECT AC.Name as [Alert Name] ,CASE WHEN MINUTEDIFF(A.TriggeredDateTime, GETUTCDATE()) > 1440 -- More than 1 Day (1440 minutes) THEN (TOSTRING(ROUND(MINUTEDIFF(A.TriggeredDateTime, GETUTCDATE()) / 1440.0, 1)) + ' Days') WHEN MINUTEDIFF(A.TriggeredDateTime, GETUTCDATE()) > 60 -- More than 1 Hour (60 minutes) THEN (TOSTRING(ROUND(MINUTEDIFF(A.TriggeredDateTime, GETUTCDATE()) / 60.0, 1)) + ' Hours') ELSE (TOSTRING(MINUTEDIFF(A.TriggeredDateTime, GETUTCDATE())) + ' Minutes') END AS [Active] ,A.TriggeredMessage AS [Message] ,AO.EntityCaption as [Triggering Object] ,CASE WHEN [AO].RelatedNodeCaption = EntityCaption THEN '[Self]' ELSE [AO].RelatedNodeCaption END AS [Related Node] ,AO.EntityDetailsUrl as [_LinkFor_Triggering Object] ,CASE WHEN AC.Severity=0 THEN '/Orion/images/ActiveAlerts/Informational.png' WHEN AC.Severity=1 THEN '/Orion/images/ActiveAlerts/warning.png' WHEN AC.Severity=2 THEN '/Orion/images/ActiveAlerts/Critical.png' WHEN AC.Severity=3 THEN '/Orion/images/ActiveAlerts/Serious.png' WHEN AC.Severity=4 THEN '/Orion/images/ActiveAlerts/Notice.png' END as [_IconFor_Alert Name] ,CONCAT('/Orion/NetPerfMon/ActiveAlertDetails.aspx?NetObject=AAT:',A.AlertObjectID) AS [_LinkFor_Alert Name] ,AO.RelatedNodeDetailsURL AS [_LinkFor_Related Node] ,'Ack' AS [Ack] ,'/Orion/Netperfmon/AckAlert.aspx?ObjID=' + ToString([AO].AlertObjectID) AS [_LinkFor_Ack]FROM Orion.AlertActive AS AINNER JOIN Orion.AlertObjects AO on A.AlertObjectID=AO.AlertObjectIDINNER JOIN Orion.AlertConfigurations AC on AO.AlertID=AC.AlertIDLEFT OUTER JOIN Orion.NodesCustomProperties AS NCP ON AO.RelatedNodeID=NCP.NodeIDWHERE ISNULL(A.Acknowledged,0)<>1 ORDER BY A.TriggeredDateTime DESC
