NCM can't add fotigate node, when I test login always fail timeout, anyone can suggest me to solve the issue?
What version FortiOS? You may be running into issues like Fortigate new sofware SSH error with NCM
NCM uses an SSH client lacking modern algorithms, and newer versions of FortiOS removed the only older schemes NCM supports
Open a support ticket, explaining that you need to be able to backup your FortiGate's using modern encryption algorithms. They should be able to supply you with a "Buddy Drop" hotfix and a set of instructions for updating some of the wodSSH.NET components, and the advanced configuration settings to allow newer devices to be backed up.
This is what I did, and it worked for me.
Hi Phillip
Do you have a ticket number we can reference? I did log a ticket a few weeks ago and all that happened it was logged as a known issue and raised as a feature request.
Hi David. The reference you need is - "01574047 - WeOnlyDo.Client.SSH.dll does not connect to FortiOS 7.0.14 for backups"Hopefully that will help you get the assistance you need. If they won't play, let me know!Philip
Thanks Phillip.
Buddy drop file supplied and dlls replaced and advanced configuration changed as per instructions.
All firewall backing up again.
Many thanks
