Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
msde 2 ms sql
Cygnuz
i'd like to migrate from a msde to a ms sql db. I think the steps would be:
1) backup msde db.
2) revove msde db.
3) install ms sql db.
4) restore the db from the backup!
Would it work in your opinion? any hints or comment would be appreciated!
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Looks good Cygnuz.
You may have to run the Install Wizard again & point Orion to the new MS-SQL NetPerfMon DB. It will automatically setup DB permissions & passwords for the NPM poller & Web engine.
-=Cheers=-
NG
Cygnuz
Thanks for your answer!
should this be step 3.5? so when I restore the db it should have all the table created with the right permissions. is it right?
Network_Guru
I would just run through the 4 steps you have listed.
(First step is to stop all Orion services).
If Orion does not recognize the new DB, then run the DB install portion of the Install Wizard & point it to the new DB. (I'm no DBA, so I don't know if the MS SQL DB will be found & used by Orion after the upgrade). I've only ever used the Enterprise SQL.
-=Cheers=-
NG
Cygnuz
really thanks for your answers
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
