Good day,
I just took over the monitoring of our servers but running into an issue. When I add a server via the agent install, the installation succeeds but I am unable to manage as node. Am I adding the server incorrectly?
Are you installing the agent from the Solarwinds GUI, or just installing it manually?
Have you looked in Settings - All Settings - Manage Agents, then check the box next to the node and then click Manage As Node?
Installing from the Solarwinds GUI
Yes, that is where I am clicking. Is there anything in particular that I need to specific after I click "manage as node"? I left all the information as default and proceeded.
It should end up looking similar to this after it is managed correctly. This is a Linux node, WIndows looks the same.
Yeah, it isn't changing to that. It looks like this even after going through the manage as node option.
But I am starting to wonder if it is because the vcenter is a node.
Usually the spider looking icon (agent icon) turns green after you check the box and click Manage as Node
Yes, it doesn't seem to working. I have already created a case but wanted to see if it was something simple that I was missing.
Yeah the weird spider icon normally means the agent is reporting back in, but there isn't a node associated with it.
I sometimes manually add the node (Settings -> Manage Node -> Add Node) and select the agent option for polling. I normally only see that though whenever I've manually downloaded and installed the agent though. So sounds like some kind of bug if you are pushing through the SolarWinds web console.
I have the server as a node but once I changed the polling to agent, it seems to be working now. Thank you for the assistance.
