I am unable to import syslog rules in LV in new version 2024.1 where exported syslog rule from 2020.2.6 version, after changing file format to .json also.
Did you migrate directly to 2024.1 from 2020.2.6? --> YES.
We have 2 instances, Instance-1 migrated to 2024.1 from 2020.2.6, another one Instance-2 currently running 2020.2.6, some syslog rules running in Instance-2, need to import those rules in Instance-1 . i.e running new version 2024.1
@sivananda Did you migrate directly to 2024.1 from 2020.2.6?If you can still revert to 2020.2.6 then you can go to 2023.4 first before going to 2024.1https://documentation.solarwinds.com/en/success_center/orionplatform/content/release_notes/solarwinds_platform_2023-4_release_notes.htmFrom 2020.2.6 to Solarwinds 2023.4, legacy rules can be migrated to OLV / LA
Thank you.
Then you should open a support ticket to have it reviewed.
No, I am trying to import legacy syslog rules in LV
Any chance you'd be willing to paste as code (Insert > Code > Paste in and select JSON as the format) one of the JSON files?
