This page: Custom query to create a node downtime report (site.com)
... is written for Report Writer, which is no longer used in Orion.
Is there an updated version of this, either in SQL or SWQL? I'm after the equivalent.
Just use the code block on the page you linked.
We are running 2023.4.2 and I've just tried it in the Database Manager and it runs just fine once I edited out the section: AND NodeID = '1'
So adding that code block to a Custom Report using the 'Advanced Database Query' option will allow you to directly copy/paste that code in "as is" except for editing the line above to remove (to report on all nodes) or adjust to suit the node you are interested in.
Oh, and be sure to click on the 'Query Type' radio button for SQL.
Still worth the challenge of converting to SWQL so you can take advantage of the additional features (IMHO).
SWQL?? hmmm this looks like it works. Gah, easier to start fresh with all the embedded sql statements.
This seems to work. Please try it and let me know.
SELECT N.StatusLED, N.Caption, N.NodeID, StartTime.Message, StartTime.EventTime AS DownEventTime, ( SELECT TOP 1 EndTimeTable.EventTime FROM Orion.Events AS EndTimeTable where EndTimeTable.EventTime >= StartTime.EventTime AND EndTimeTable.EventType = 5 AND EndTimeTable.NetObjectType = 'N' AND EndTimeTable.NetworkNode = StartTime.NetworkNode AND EventTime IS NOT NULL ORDER BY EndTimeTable.EventTime ) AS UpEventTime,MINUTEDIFF(StartTime.EventTime, ( SELECT TOP 1 endtime.EventTime FROM Orion.Events AS Endtime where EndTime.EventTime > StartTime.EventTime AND EndTime.EventType = 5 AND EndTime.NetObjectType = 'N' AND EndTime.NetworkNode = StartTime.NetworkNode ORDER BY EndTime.EventTime ) ) AS OutageDurationInMinutesFROM Orion.Events as StartTimeINNER JOIN orion.Nodes as N ON StartTime.NetworkNode = N.NodeIDWHERE (StartTime.EventType = 1) --AND N.NodeID = '1' used to filter by nodeidand StartTime.EventTime IS NOT NULLORDER BY N.Caption ASC, DownEventTime DESC
honestly starting fresh in swql might have been MUCH easier.
Yeah - I don't have time today, but I would start with the two subqueries and then wrap in the rest.
yeah my conversion tends to return all the outages... ugh
I'll leave that to someone far better versed in SWQL than myself...
