Can someone share the steps to configure SolarWinds for the first time from scratch, any detailed explanation that would help someone with less experience in SolarWinds?
www.youtube.com/watchdocumentation.solarwinds.com/.../install-new-deployment.htm
If possible need specific steps followed while configuring instead of Solarwinds administrator or installation guide
It may help to start with the free online training under the SolarWinds Academy - Training and Certification above. Every deployment has different requirements on what you want observed. The on-demand training can give you specific ideas on where you want to start.
SolarWinds Configuration This one has step by step instructions. Do you want an assistance with the installation? Someone that will be there while the installation is running?
As of now we are not installing SolarWinds, I need the steps to make document on the configuration ,requirements and best recommendation throughout the configuration steps to show this to client
Why would you need steps and create a new document about configuration and requirements if everything has already been documented and is readily available online? isn't that a little redundant? Either way, the youtube video above and the link should cover what you are asking.
Document is presented to client, hence the official document cannot be used, also is there any other document other than SolarWinds Configuration
Are you looking for like hardware requirements ..? This would be a good document for that:documentation.solarwinds.com/.../solarwinds_platform_2023-4_system_requirements.htm
