Login On Failure Log
Login On success Log
when i switch telnet remotely the Switch restart auto how to fix pls help cisco 2960 x S ver 15.0
Can you clarify your issue, as I am unsure on what your objective is and the problem you have to achieve
when i run this command in cisco 2960 x switch
i access via telnet switch when enter password the switch reboot auto
So you are configuring the audit log definition on the switch and have seen that when you apply this configuration, if you then login remotely using Telnet it causes the switch to reboot without request?
This is not something I have encountered and suggest this is more something you need to raise a TAC case with Cisco. The configuration for enabling logon auditing should obviously not result in such a condition.
Well, for one, STOP USING TELNET. Very insecure. Switch to SSH version 2.
Hopefully you're running one of the latest versions of 2960X software, pretty sure that platform has been out of support for years. If not, upgrade to the latest version of the software for it and it will probably fix your issue.
But, stop using TELNET!! :-)
I stand corrected, some of them are supported to some extent through 2027! Wow, didn't expect that...
